Infinite prime control panel
120 V AC. Presumably that's RMS , because peak voltage is nearly 250 to 300 V. This is the waveform on a scope. Anyway I had a stroke of luck. My old sounder has the exact same piezo transducer so I'm going to use that. Hopefully it's the same voltage, but it looks totally identical. The HKC sounder is taking nearly 200 mA when sounding after I replaced the piezo element, which tallies with the 250 mA peak they give in the spec. Also the 6 V battery is still working fine. After 15 mins of alarming, voltage fell to 5.75 V. -
gardtec800 series engineer locked
PeterJames replied to Phil Reed's topic in Control Panels (Public)
No easy way to unlock it unfortunately the panel is over 15 years old and obsolete, its likely to have unreadable keypad pretty soon its a common problem with old Gardtech's
Who's Online 0 Members, 0 Anonymous, 74 Guests (See full list)
Total Topics446.3k
