  1. Today
  2. Iirc you can replace an existing but not add or remove devices with out software
  3. Hello, I am interested on algotec protec 6500 panel, can i add device in loop without software? and how can i do it?
  4. Yesterday
  5. QFA they will charge to sort it out, but like most good companies they will have a solution
  6. none are likely to work correctly when needed, you either need a digiair as signalling up grade, of replace the controls to one which uses an app
  7. Thank you, your help is much appreciated. Regards.
  8. If its still under contract speak to them and let them sort it out.
  9. You could try but there is no guarantee it will work properly. You will also have the issue that a power cut will disable the alarm signalling. Best option is to upgrade the system/signalling to a more modern digital compatible one.
  10. I have a very old intruder alarm which uses an autodialler to contact ADT for monitoring. I am about to be switched to Digital Voice by BT. I understand that I can use an ATA so that the alarm can still contact ADT via Digital Voice. What ATA would be best for this? Thanks!
  11. A D B B C T D A S 49
  12. Last week
  13. Good evening all. Looking for some help regarding wiring a Texecom Odyssey XB-E bellbox into a very old but working perfectly ADE Optima 2 Plus control panel. Been something like 30 years since I ventured up the ladder to fit the original Flashguard bellbox which has recently failed. I've sourced the aforementioned Texecom bellbox as a replacement and would much appreciate the kind folk on here confirming what I think to be the correct connections between the two as this would hopefully help me avoid making any more than one trip up the ladder to complete the job. (Several trips up the ladder result in much aching of my, these days, not so young legs !) I've included a diagram of the terminals at the bellbox and a picture of the terminals at the control panel. Your help / advice with this small issue would be very much appreciated. Regards, Dave Walton.
  14. Thankyou again. Sorry mistook 'everything' to mean 'every-pir', but yes everything means everything!
  15. so even if you only have 1 keypad connected on line 1 addressed as 1 it still doesnt work. Have you also tried a temp small cable just out of the panel to prove the wiring?
  16. It depends on what panel maybe upload a photo of it?
  17. Earlier
  18. The red light is normal the tamper light could be anything, every circuit has a 24hr alarm circuit called tamper, if someone tampers with the alarm while its unset the alarm activates to warn the owner that someone is tampering with it. Putting the wrong code in the alarm several times could also cause tamper. As SWB says its difficult to tell you what the cause or fix is without more info and knowing your technical ability we are alarm monkeys not magicians
  19. We have no idea what model panel you have but seems like you have a tamper fault which will need diagnosis. Understanding electronics and owning a multimeter would be a starting point, there's live electrics inside the control box.
  20. Mrs D
    Mirfield Mum
    Good Morning. My son's Alarm box is showing a Red Power and Tamper light. Does anyone have any suggestions as to whether this can be fixed without and engineer?
  21. Well I assume eBay new panel doesn't work so forget it
  22. None of the lines are working, not even line 1. If I connect my keypads to the other panel (new) it works perfectly. So I now know the issue is with the panel and it affects all the AB lines. Is there a way I can get this fixed or what could be the problem?
  23. So going back it seems you think both keypads work But are sending line 2 downstairs Why not just put everything on to line 1?
  24. I have connected to all the lines and changed keypad addressing as well and still same result, still no comms.
  25. Sorry for getting back to you late. By being new I mean I am not familiar with the Honeywell panels. I stand to be corrected in this, upon powering up a new panel it scans the modules on the bus line an picks them up for enrolment. Mine when I connect the keypad alone it keeps beeping and flashing stars, it does not get to a point where it shows the panel information. I suppose this means there is no communication with the panel. How do I fix this now, both keypad and panel are new from the box, returning this for replacement will take me months +. I connected the 2 with twisted pair mylar.
  26. And not cut the spares off ......
  27. Thanks everyone. Cable is run now. Looking to get bell, panel and box. 8 Wired Q20s, so not wedded to any manufacturer yet. Can I use my 8 core to the keypad? Can I use the 8 core to the bell box, or does it need a second power supply cable? Thanks again.
  28. no just exit engineering & it will show the the number of modules added / removed.... Sometimes using the magic word of Izzy-wizzy, let's get busy, helps ?
  • Who's Online   0 Members, 0 Anonymous, 48 Guests (See full list)
    52,003
    guramkhasia
    guramkhasia
    446.1k
