Rafiki QuadNet Video
During training i grabbed a video of rafiki's new Quadnet and Duonet Range.
Ill do a review later on, but i was massivly impressed with this panel.
James
Copyright
© © The Security Installer
Misc Images
· 22 images
  • 22 images
  • 26 image comments
jb-eye
Re: The watch. I trust you dont wear it when working near panels. Id kick your ass from one side of the room to the other for wearing a metal wrist wach on my shift.
james.wilson
Yep i do, and a wedding ring, mobile on pocket and i get a screwdriver near a panel from time to time.
why?
jeferson
hi
on duenet panel The backup battery is damaged and after replacing the battery, the panel codes do not work.
can u help me?
jb-eye
replacing a battery wouldn't prevent the panel from working.
Im sure you haven't been daft enough to drop the power.
What does it say say when you re-initialise?
jeferson
Expand
Thank you for your answer.
The system works without problems but the  code does not work.(user , supervisor and Engineering codes)
After entering the codes, it writes on the screen that the wrong code has been entered
MrHappy
Expand
did you ever use the system before attended the fault ?
I assume the codes can be changed from the defaults ?
jeferson
Yes. Before replacing the battery, the codes worked properly. User 0125 and engineering code 3647
MrHappy
you replaced the pcb battery ?
jeferson
Yes. The battery was broken and the system did not start
jeferson
There is a jumper for the user on the board, but in this case it is not possible to send data to the system
MrHappy
are this controls you have been given / bought of ebay ?
MrHappy
I guess we are down to Default codes /full system
Replace controls ?
