ScorpioInstallations Posted October 5, 2007 Posted October 5, 2007 Just like tha ! Huh Huh ha do you know why when the alarm is set, when i move across the pir the light goes blue and i hear a click in the control box but the alarm does not sound or go off. Post a Diagram fist so we can see how you've weired your bell. Never Teach Your Apprentice Everything You Know
Guest anguscanplay Posted October 5, 2007 Posted October 5, 2007 OK that make sence thanks.do you know why when the alarm is set, when i move across the pir the light goes blue and i hear a click in the control box but the alarm does not sound or go off. thanks for all your help cause you said at the top you aint connected the blue and yellow wires ? you will probably have to " tell " the curcuit to work using the programming but we aint really supposed to post how THAT goes edit: just read you say it clunks in the control box doh you`ll have your bell wrong, like mr whitenoise says " drawing would help....."
andyrav Posted October 5, 2007 Author Posted October 5, 2007 Thanks i have wired it as per your diagram i have not wired a bell yet. just added a horn when i set the alarm and i walk past the pir the relay in the control pannel clicks but there is not sound from the horn and it does not say anything on the lcd panel. if i add a pannic button to zone 1 and activate it that works both in set and unset mode the Pir is on zone 2 Thanks Just like tha ! Huh Huh ha Post a Diagram fist so we can see how you've weired your bell.
ScorpioInstallations Posted October 5, 2007 Posted October 5, 2007 i have not wired a bell yet.just added a horn when i set the alarm and i walk past the pir the relay in the control pannel clicks but there is not sound from the horn and it does not say anything on the lcd panel. if i add a pannic button to zone 1 and activate it that works both in set and unset mode the Pir is on zone 2 How is the PIR programed? How are you setting the alarm? Never Teach Your Apprentice Everything You Know
kka Posted October 5, 2007 Posted October 5, 2007 ? for the others, is it still practise to fit an eol resistor across zones not being used (to mimic tamper valve) or do you omit the zone in programming Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Guest anguscanplay Posted October 5, 2007 Posted October 5, 2007 ? for the others, is it still practise to fit an eol resistor across zones not being used (to mimic tamper valve) or do you omit the zone in programming we fit the resistor and with the panel been eng reset for tamper as per regs it means no one else can fit owt without us knowing about it we used to programme it off but realised we were missing out on loads of money hmm ? LOL
kka Posted October 5, 2007 Posted October 5, 2007 i was dropping a hint Angus, good practise... good tip thou : Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
alterEGO Posted October 5, 2007 Posted October 5, 2007 we fit the resistor and with the panel been eng reset for tamper as per regs it means no one else can fit owt without us knowing about it we used to programme it off but realised we were missing out on loads of money hmm ? LOL You would get CP tamper anyway so how do you work that out?
Guest anguscanplay Posted October 5, 2007 Posted October 5, 2007 You would get CP tamper anyway so how do you work that out? thats true, hmm, been wasting my time then last few service visits grr banghead
alterEGO Posted October 5, 2007 Posted October 5, 2007 thats true, hmm, been wasting my time then last few service visits grr banghead lol, i told you i'm good it was a schoolboy error though Tell your new improver to give me a bell if he gets stuck
