Some Obvious Questions From A Newbie
Guest PaulMaddocks
Guest PaulMaddocks
Hi all,
First post on the forum, so far found it very useful but I have a couple of specific questions I need some answers to before I can wire up my panel.
I have a scantronic 9651 with 5 Honeywell PIRs and 1 smoke detector. I have checked the manual for the control box and just need to confirm the following:
Power for PIRs etc are all connected the AUX power connector strip (as this is the only power output I can see on the board).
The alarm connections on the PIRs (each connected on a different zone) appear to share a connection block, e.g for Zones 1 and 2 there are 3 connections, am i correct in assuming that Zone 1 PIR Alarm + goes to first connection, return from Zone 1 middle, Zone 2 return to middle and Zone 2 Alarm to 3rd connection. (Apologies if this is totally off the mark but I could not see how else it goes)
Finally, could someone be kind enough to post a very quick diagram on FSL wiring, I understand you need to wire the 2 different resistors into each sensor, but not got a grasp on which to where.
Again sorry for the obvious questions but I am keen to get my head around this and get it all done myself. Programming I got no problems, just the physical.
cheers,
As far as the wiring on the board - you seem to have that right - you have two sets of AUX 12V on the board, right next to each other.
The zones on the board - 1 Commn 2, 3 common 4 etc - dead right.
The resistors - wire the larger one in PARALLEL with the C/NC contacts of the detector, and the smaller value resistor from one side of these contacts to one side of Tamper (ie, in SERIES with the C/NC). Now you have Two resistors in one side of C/NC. Put one zone leg into the other side, and the other to the empty tamper terminal.
D7
Guest PaulMaddocks
Ok that sounds all good to me.
To check I understand correctly, is the diagram below what you descibed?
Might just have got all this sussed. I guess for power they give me 2 lots of terminals so I don't have to stuff all the wires into just 1. I can load them both up evenly?
Thanks for you help.
Paul
The picture looks correct to me (not sure on the values, I don't do much with Scantronic but the wiring looks ok).
As for the power terminals, most people find it easier to wire all the power cables from detectors to a terminal block and then take 2 cores from some .75mm flex to the aux terminals to avoid having to jam loads in one terminal.
Depends how many cables you end up with, 3 or 4 is ok, more than that and you really want to be looking at doing it the above way.
scantronic still use 2k2 and 4k7 resistors
Life is like a box of choclates.....if you dont get there first your left with all the naff ones
can just go closed loop,its not like its a high graded panel now is it.
cheers
Guest PaulMaddocks
Ok guys that cool, thanks for all your input. It was mainly the FSL wiring so if I have that right I should be cool.
cheers
