C&k Securit 800l+ - Missing Step After Changing Battery
Quartz
Today there was an extended power cut and the external bells went off and the main battery decided to fail so I couldn't shut them off. I rang the local police to advise them of the situation, just in case someone rang them. The local company diagnosed the problem and wanted
Guest anguscanplay
disconect the battery, turn your mains off - wait ten seconds then mains back on, reconnect the new battery, close the lid and it should (only should mind) be working off your code
I'm much obliged to yourself and Fastcar (who PMed me with the same advice). This did the trick.
