Posts
476 -
Joined
Last visited
Days Won
1
Content Type
Profiles
Forums
Events
Downloads
Gallery
Blogs
Everything posted by Alpat Systems
What cctv brand are fellow installers using?
Alpat Systems replied to Sirtoddius's topic in CCTV & Access Control
We use https://www.videcon.co.uk/ as the alternative to HIK The majority of Councils / Government customers run there CCTV/Security projects under NEC3 contracts and CDM rules. They expect the security experts they have chosen, who would have been selected to go onto there procurement framework to be principal Designer/designer. Its extremely rare you will come across a government institute who would become design responsible. -
CCTV Sub contractors required All regions Install teams / service, small works engineers Must have experience of working in a retail environment CSCS, IPAF and references required Experience of IP and Analogue systems essential, including Pelco/BBV matrix, Samsung and HIK Please contact via PM, including regions covered, experience, day / callout and hourly rates. A non disclosure and non competitive agreement will need to be signed.
CCTV Sub Contractors, All regions
Alpat Systems replied to Alpat Systems's topic in UK Security Sub-Contractors
bump.. Still looking for sub contractor UK wide. -
CCTV Sub contractors required All regions, 1st/2nd/commission, fault, maintenance Must have experience of working in a retail environment CSCS, IPAF and references required Experience of IP and Analogue systems essential, including Pelco/BBV matrix, Samsung and HIK Please contact via PM, including regions covered, experience, day / callout and hourly rates. A non disclosure and non competitive agreement will have to be signed.
Description: Hikvision have implemented a plugin integration with Net2 using Paxton's Video Integration Platform. This allows Hikvision NVR's (Network Video Recorders) to be listed as a camera integration within Net2 and provides an easy configuration of the NVR details and camera detection. These cameras can be associated with individual doors to monitor access. Currently the system is only able to associate 1 camera per door. Net2 compatibility: v5.01 onwards Languages available: Most languages available How to buy: www.hikvision.com or email: support@hikvision.com Download Hikvision driver for Net2: ftp://Hik_Paxton:Paxton_Hik@ftp.hikvision.com Contact telephone: +86 571 8807 5998
That's wrong Camera should fit "flush" with no gap Check it is the correct bracket for the camera, there's quite a few Examples of correct fitting:
Due to the location of the site we were limited by the connections/speed available. Ideally we would have gone leased line, but BT quoted £300k to install fibre. and the permits required to dig was just getting silly. Luckily there where enough copper pairs left in the existing BT cable to go with a dual ADSL solution.
Its a 3U Cisco blade: Router/Firewall Server Switch But in order to run all that: WAN Link (bonded ADSL) Internals of cabinet BT Router top Backup router, should the one in the Cisco blade fail
That's delivery companies for you! Dropped them about 100m from the entrance in the carpark. There's over 250kg of weight there too
Top image is, show the old Milestone server at the bottom as we prepared to move it onto the new virtual server. Bottom image is it moved into new sound/dust proof cabinet
VMWare management using VSphere (desktop client) is simple. On each Virtual server you can set max/min CPU, memory, LAN usage. So for CCTV we priorities LAN bandwidth, but not processor and memory. Its so easy to monitor everything through one client. Typical VMWare setup: ESX server host Virtual Centre Server Virtual Infrastructure (VI) client Web Browser License Server Database
We did briefly look at oracle VB, but the lack of support was an issue. Obviously cost wise VB wins hands down. VB is great for desktop virtualisation, VMWare for enterprise solutions VMWare also does quite a lot more, and is considerably quicker From what I remember the main issue for us with VB was controlling hardware ports through each virtualised server
Another vote for Milestone + Dell Server We've recently created a Cisco blade "security" server with router/firewall, VMWare with servers for Milestone CCTV, Paxton Net2 for access. Nice one "box" solution
First time in 10 years were quiet on the infrastructure side. April usually triggers orders from our bigger customers. Speaking to them it appears there budgets have been cut, causing a knock on effect. Project management side is still healthy.
What BNC connectors are you using? TVI can be very fussy with the BNC termination compared to "old style" analogue. Make sure when terminating the BNC that the foil shield and braiding on the cable is cut back so its well clear from the centre conductor/pin. You don't normally have to worry about this so much with analogue but I've witnessed a similar fault to what your describing. Just for test purposes try connecting the camera to the DVR using CAT5 and baluns
- 19 replies
Pivot Attacks Using Dvr's
Alpat Systems replied to sixwheeledbeast's topic in Members Lounge (Public)
We advise the client of the potential risks and offer a solution. This is either re-configuring there existing routers/switches/firewalls or installing new CIsco kit or if on a budget we'll use smoothwall http://www.smoothwall.org/ For me, keep the network security separate. Its too complicated for a CCTV installer to undertake Don't forget a single DVR can provide a route onto a network. Below is an example of a system we've recently installed. Its using a Cisco 3925 service router, with layer 2/3 switch, server blade and application acceleration. Installed on the blade server is Milestone software for the CCTV (But this could have been a separate DVR plugged into the switch). Data/Voice/CCTV is all separated by VLANs and QOS is used. -
We mainly use Axis with Milestone for I.P, been a partner from the very beginning. Briefly tried Mobotix/Pelco/Bosch/Verint etc but they all seem to be playing catch up to Axis. We've got some very large complex systems out there using analytic's and linking to various 3rd party systems.
It depends on which 800 series router it is as to whether http is enabled. We normally disable it after programming. Https is normally still available. If you have a cable you can try programing it. I bet there's plenty of YouTube videos on how to do it.
A Cisco Certification How did you try to browse to the router?, was it via the web (I.E, Chrome etc) by any chance http://www.cisco.com/c/en/us/td/docs/routers/access/800/software/configuration/guide/SCG800Guide.pdf
The majority of modern lifts have spare pairs available in the control wires, some may even be assigned for cctv use. Don't use wireless, it won't work in this situation
Cctv Distortion Different Electrical Phases
Alpat Systems replied to NotHeardofThat1's topic in CCTV & Access Control
Use a UPS on the DVR on another note... This is also a common fault with data networking when one network switch is on one phase and connected via Cat5/6 to another on another phase. You get around this by connecting them together via fibre optic cables. -
Anybody With Experience On Farm Jobs?
Alpat Systems replied to matt5595's topic in Members Lounge (Public)
http://www.knightfireandsecurity.com/catalogue.asp?id=5 -
With the IP we've had firmware issues too. At the moment we have the HDTVI on test, its looking promising.
Personally I'd stay away from the 1280H, and look at Hikvision HDTVI http://www.hikvision.com/europe/Press-Release-details.asp?id=2660 http://www.hikvision.com/europe/products.asp?cid=270516
