J&D Security
Trade Full Member
Everything posted by J&D Security
  1. Did you check the back tamper was closed, if he fitted the back plate upside down then the back tamper would never work unless the sensor was also fitted upside down.
  2. J&D Security replied to Ack1234's topic in Guest Forum
    You've asked for two things which are against the forums rules. No defaulting info, or codes
  3. I'd say they use a lot of Inner Range kit for intruder and access control, it's an Australian product, I've used it a couple of times in the UK.
  4. Have you got tones switched on on the Dialler on the phone, the SD1 needs either pulse dialling or short duration tones. Also the 8 button should be pressed for about 1 second.
  5. http://www.electronics-tutorials.ws/electromagnetism/hall-effect.html
  6. Welcome to London where the roads belong to cyclists and pedestrians and motorists are a second thought. Only in london are pedestrians on walk for 3 minutes and cars on go for 3 seconds
  7. Thanks again. There's no alarm monitoring just remote client access with the mobile app. So over all a good product and worth the money. Thanks for you advice
  8. Hi, I was after peoples opinions on HikVision's HDTVI range of cameras and DVRs Thanks
