Installation Manual Optima Compact
Guest Goatsmilk
Guest Goatsmilk
Hello first post here so please be gentle....
I'm looking for an installation manual for an Optima Compact as my in-laws had one fitted 8 months ago. The installer has not left any manuals not even the operating one, he did remember to leave the bill though. The service timer has been set up and is now bleeping, there was no mention of this being done or was any choice given, which I feel is quite under handed.
I either need the full manual or the procedure to turn off the nuisance reminder bleep.
I have fitted a few alarms at home and for family mainly Veritas R8's and a 700L, I just happened to be in another country when the in-laws had a panel pack up and needed a new one prior to hols. So I have an understanding of what to do once I have the instruction manual.
Also does anyone know if there is an override for the engineer code or will the operators code work for what needs to be programed? Failing that is there a way of getting an override code from the manufacturer?
Regards
Stu
Regards
Stu
This site does not give out engineer manuals unless you are in the trade and can prove it.
The service timer has may have been set but the system is only telling you that it needs a service. Nothing underhand.
No user overide for the engineer code, there is no such thing as an overide code(even from the manufacturer)
Call the installer hes your best option failing that you need a new engineer or buy a new panel.
Guest rjbsec
Regards
Stu
If fitted 8 months ago then a warranty should apply - call the installer and get him to return and put the matter right and request the User Guide which he should have left.
We cannot give you an installation guide or any advice on codes and it would be unusual for an installer to leave the installation guide.
Tell the installer that your mum doesn't want the service reminder and ask him to switch it off.
Guest Goatsmilk
I expected that manuals would not be given out, but thanks anyway, I used to work for an elec wholesaler and still have a few mates there, will have to get a photo copy, or get a new panel for around
After all a clean of the PIR's and a new battery is an easy thing to do and does not cost much, unless the installer does it then it would be expensive judging by the price he charged to fit a basic new panel using the existing 6 core.
Theres more to servicing than that and you not only paying for what an installer does on the day.
Nobody works for nothing and remember its easy to moan about the price after it was done!! Your inlaws should have queried the price at the time and again your not just paying for the panel and the time to install it.
Guest Goatsmilk
I know they should have queried the price, I said just that, but they had no clue of how much it should cost until I told them what the parts cost. also lets face it there ain't a lot to servicing a home burglar alarm, no matter what installers try and make out, it's just an easy way of making extra cash on the whole, I recall a high percentage of installers saying just that when I used to sell systems to them.
Stu
Stu
Dream on mate, theres more to it than you think.
Guest Goatsmilk
Well how come I have fitted and maintained my own alarms with no problems what so ever, I'm either super human or it's dead easy, I guess that latter.
If there is more to this black art then please expand and justify the costs.
I think we will just have to agree to disagree in the end though, as I'm not into falling out with someone I don't even know over a trivial matter.
But thanks anyway for the original replies and advice.
Take care
Stu
Take care
Stu
Dont need our help then cause its dead easy ;)
Fall out, now you are dreaming.
if i was to take you to a large high school or industrial unit with a system with over 100 zones intergrated with the CCTV and fire system would you be so quick to say its easy then??
I think not
The kind of kit your using is very low end domestic stuff anyway.
