Guest Jonbhoy Posted April 1, 2006 Share Posted April 1, 2006 Hi all, Bought a CCTV cam and receiver from ebay a few weeks ago and on the whole pleased as for the price it isnt a bad base entry system.Its a 1.2ghz system (Got a 2.4ghz system but reception was awful where i had it....plus my wireless keyboard and mouse stopped working with it on!).I have it set up at the front door which is fairly shaded but not to bad and the picture is usually pretty sharp.This is the cam i bought.... http://i6.ebayimg.com/01/i/06/2a/84/ba_1_b.JPG One problem is it has one of those aerials that is like a piece of wire coming through the top of it and im wondering if this is the problem.During the day i find the picture gets darker and darker (Not just the natural light fading) but if i go out and more the aerial about a little i go back and check the picture and its back to being bright and sharp.I have it fitted where there is an overhang of only about 2 inches between the cam and the woden over hang but as the aerial can bend dont see that as a problem.Anyone had similar with theirs? Also as it seems a fairly enclosed casing is it possible for a specialist to fit a more upgraded aerial to them such as a good rubberised one? Many thanks all, Jon Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10039-wireless-cctv-aerial-problem/ Share on other sites More sharing options...
Rich Posted April 1, 2006 Share Posted April 1, 2006 Hi Jon, You can get 2.4GHZ antennas but I have never seen a replacementfor a 1.2GHZ so think you may have trouble, and even then alternative antennas are for the receivers only not the transmitters. The fading sounds like a problem with the camera/transmitter, I doubt you will find a cure to this. Did you buy the equipment from a ebay shop in the UK or a private seller? Personally I would be asking the seller to replace the equipment, or at least ask them to find a solution. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10039-wireless-cctv-aerial-problem/#findComment-93679 Share on other sites More sharing options...
Guest Jonbhoy Posted April 1, 2006 Share Posted April 1, 2006 Hi Rich, Many thanks for your reply.Yes all i have noticed is 2.4ghz aerials too . It was a private seller and sadly no answer to any of my emails.I bought it for about Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10039-wireless-cctv-aerial-problem/#findComment-93683 Share on other sites More sharing options...
Rich Posted April 1, 2006 Share Posted April 1, 2006 I doubt you will find a company to do what you want, and if you do find someone that will attempt it, your probably looking to pay Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10039-wireless-cctv-aerial-problem/#findComment-93685 Share on other sites More sharing options...
Doktor Jon Posted April 1, 2006 Share Posted April 1, 2006 Evening Jonbhoy, This is a bit of a silly suggestion for you to try. See if you can straighten out the aeriel in a horizontal plane (perhaps using tape to hold it in position, then reposition the receiver aeriel so that it's pretty much in the same plane as the TX aeriel. This may help .... or it may not! If the receiver aeriel is detachable, it may be possible to get hold of a replacement higher gain type. How far do you think the camera is located from the receiver? for now, another Jon Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10039-wireless-cctv-aerial-problem/#findComment-93720 Share on other sites More sharing options...
Guest Jonbhoy Posted April 2, 2006 Share Posted April 2, 2006 I doubt you will find a company to do what you want, and if you do find someone that will attempt it, your probably looking to pay Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10039-wireless-cctv-aerial-problem/#findComment-93775 Share on other sites More sharing options...
Guest Posted April 2, 2006 Share Posted April 2, 2006 Thats why i was saying about maplins,didnt think they could help with the fix but might know some guy or backstreet small shop that maybe does electronics small scale.Even an electrical hobbiest might be able to do it if its a case of resoldering a new aerial onto the circuit. tbh, I'd personally steer clear of anyone that uses Maplins as people who actually know what they're doing don't buy stuff from them. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10039-wireless-cctv-aerial-problem/#findComment-93776 Share on other sites More sharing options...
morph Posted April 2, 2006 Share Posted April 2, 2006 Remember that the ariel and transmitter/ reciever should be manufactured to a specific standard and if you alter it and it causes interference to other users, unless you have a license covering the modified equipment, you could be liable to a vist from the men from OFCOM and that could be very costly. Just something you should consider, before modifying any radio transmitters/ recievers. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10039-wireless-cctv-aerial-problem/#findComment-93844 Share on other sites More sharing options...
Guest stevey Posted April 3, 2006 Share Posted April 3, 2006 Run a cable? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10039-wireless-cctv-aerial-problem/#findComment-93897 Share on other sites More sharing options...
Guest Jonbhoy Posted April 3, 2006 Share Posted April 3, 2006 Remember that the ariel and transmitter/ reciever should be manufactured to a specific standard and if you alter it and it causes interference to other users, unless you have a license covering the modified equipment, you could be liable to a vist from the men from OFCOM and that could be very costly.Just something you should consider, before modifying any radio transmitters/ recievers. Many thanks for that,its not something i had even thought of thats why i was looking for someone that will know what they are doing . If i was to do it i might bring gatwick air control to its knees knowing my luck ;-) Run a cable? Sadly cant as its a wireless camera , no A/V outputs on the cam to run a cable to. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10039-wireless-cctv-aerial-problem/#findComment-93909 Share on other sites More sharing options...
