Modern 3200 Series
Guest jtoolan
Guest jtoolan
Modern 3200 Series Panel
Hello Forum, trying to locate information to recode a control panel after a power outage which has reset the panel to default code (1234). The LED panel show the error code....flashing 'rt'.
I believe the model has been remarked the scantronic 9800.
Any information or advice , will greatly appreciated (knowing manuals are not available).
Regards
J.Toolan
Project Engineer
:hmm:
Morning fella,
User manual is attached.
Hope it helps
Regards
Bellman
P.S. RT indicates Remote Tamper, I.E. too many invalid keypresses without a valid code being typed in. If It has crashed on power failure I'd also check and change the back up battery. It should be changed every 5 years.
9800_User.pdf
Guest jtoolan
Bellman - thanks for the post.
I have followed reset procedure - unable to obtain 4 digit Reset code from //.National Installer.// without valid service contract. Ref: User Manual Page 14, section (e).
Any advice welcome?
The Control code shown is 00,00.
Regards
Justin
