Galazy 16+ Zone Attributes
Guest ibruceuk
Guest ibruceuk
Hi people,
I have a Galaxy 16+ and was just wondering what the Link A and Link B mean as zone attributes? what would they be used for?
cheers,
Ian
Hello Ian, the link function is used to link a zone to an output, i.e when the zone trips the link function causes the associated output to trip.
Guest ibruceuk
Ah it all makes sense now, so I'd set a zone as Link A and an associated output (to maybe switch a light) as Link A as well.
It all becomes clearer!
cheers
Guest ibruceuk
One more dumb question about "Link" attribute.
What is the sub-attribute S, W or Z for?
cheers again.
cheers
I've Used The Link Zone Atrib' For A Circuit On a Side Gate
To Chime And Do Nothing Else (No Output)
Works Well
Keep Meaning To Look At The G2 Book To See If You Can Do the Same
Guest ibruceuk
Does anyone know what the S,W or Z mean that you cycle through using # when you have selected Link A for a zone type?
cheers.
Its The SIA Programming Options
Sprinker
Fire
Heat
Gas
Etc Etc For Comms
Guest ibruceuk
Sprinker
Fire
Heat
Gas
Etc Etc For Comms
Wouldn't Fire etc go on a Fire Zone type instead of Link. What do the different ones mean. Also, can I have a zone linked to an output (i.e. Link A type) and also as an intruder zone that would activate a full alarm in the case of activation?
cheers again
