Power832 Problem
Guest andy150
Guest andy150
Hi. Really need some advice before ripping system out and installing new.
I moved into my house a year ago. It has a dsc power832 (the panel i think is pc5015
it only has three sets of buttons on the right). Anyhoo worked fine until a week ago.
The numbers 3,2,4,3 keep flashing on the screen and i can't do anything to get them
to stop. I have changed the batteries in all the sensors and also replaced the back-up battery.
Startin to get a bit minty with it and considering getting it all ripped out and replaced unless
anyone here knows anything about these things.
cheers
andy
cheers
andy
Press # then * then 2 on the keypad and lets us know what comes up on the display :hmm:
Guest andy150
wont even let me do that anymore. just buzzes when i hit 2 then goes back to flasing 3 then 2 then 4 then 3. its all very strange.
Sounds like the panel could be on remote reset, is it/was it on contract with a alarm company?
Guest andy150
I believe it was before i bought the property. But its been working fine for a year now.
British Gas alarm by any chance,
Its well worth keeping, DSC are very good alarms, what part of the country are you in, we might be able to suggest an engineer that could sort out the problem.
Guest andy150
Im in the mighty metropolis of st helens in the north west.
would prefer to get it fixed to be honest. was hopin it was a common prob that
could be easily solved, but never mind.
appreciate the replys tho
oh, and yes it is british gas.
Yes its easy solved, you just enter the reset code (Thats if its on remote reset?)
But long term, if it's just going to be a bell only system then I would get someone to program that bit out (so system is on user reset).
Also give it a once over to make sure its work ok etc :yes:
Guest andy150
its all over my head mate. Is this something a local engineer can do? or can i phone british gas
and ask them to reset it for me?
again... cheers for the replys.
andy
