Guest Posted April 13, 2006 Posted April 13, 2006 What are the Australian standards for intruder alarms & police response? would I be correct in believing that you can get an arm security guard to pop round when the alarm goes off? As per US?
1_hour_install Posted April 13, 2006 Author Posted April 13, 2006 You can get a guard to attend the property if the alarm is monitored. I would say that only about 10% of alarms here actually call anyone. The guard response is normally not used by people either as it takes them so long to get to the property. Melbourne is about 80klms from one side to the other. I would say that only commercial alarms request guards to attend. In addition to this the guards are normally told to not approach the burglars and just call police. Police will not attend most of the time unless the alarm is confirmed by a person who has seen someone in the property.
Guest ALSEC Posted April 14, 2006 Posted April 14, 2006 //.National Installer.// actually has a really bad name here. There are not many techs who will actually work for them. The only ones that will are the ones who are desperate for work which usually means they are no good. I actually met one that did not own a soldering iron or a multi meter. Things pretty much the same here as in Oz then..... (takes cover..) Only joking of course..
mjw Posted April 16, 2006 Posted April 16, 2006 Things pretty much the same here as in Oz then..... (takes cover..)Only joking of course.. don't know why A.D. are dyer
C.S TEK. Posted April 23, 2006 Posted April 23, 2006 You should aply for a job with INITIAL, There using the GE Security ATS panel. you could be top engineer as it came from OZ!! Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006
norman Posted April 23, 2006 Posted April 23, 2006 You should aply for a job with INITIAL, There using the GE Security ATS panel. you could be top engineer as it came from OZ!!He could be the 'wizard' from Oz Nothing is foolproof to a sufficiently talented fool.
1_hour_install Posted April 25, 2006 Author Posted April 25, 2006 He could be the 'wizard' from Oz lol. good one. is the ATS panel the TECOM? If so do alot of people use it over there?
