Hello Everybody
Guest Hibrid
Guest Hibrid
Im electrical engineer now specialising in the field of Security systems.
In the past 4 years I have been working with DSC and Paradox Alarm panels, Position and Hundure(based) Access Control systems and large variety of Fire Alarm and CCTV systems.
Reading this forum I was suprised when I see people mad at regulations and inspections. They should come and work here(Macedonia). There is no such thing as Security Regulations, not even on a Governmet level, which makes difficult to work if you are company with trained presonnel and you have invested in proffesinalisam. People that have watched how their alarm system is installed, go and install their neighbour's Alarm for the half prize etc. :)
Great forum though. I learned a lot of stuff in the first hour, even I who is supposed to know everything in my company. :)
Hello :)
Hmm you wire their system up wrong and after they've taken a good look, change it so it works and then change the engineer code(s) ;) (of course this is not a very advisable business practice - now where did I put that cowboy hat)
Had to read that about ten times to understand it in the way it was meant.
Guest Hibrid
Well I will try to speak in technical language only. It's easier for me to write in, and for you to understand it.
Thank you all for the Wellcome.
