Guest only1reef Posted April 14, 2006 Posted April 14, 2006 Help!! Have adopted said panel and reset the nvm chip but having the following issues as there is an external keyswitch to set / unset I have programmed the door contact as E/E and parameters 38 and 39 as lockset (opt 2) turn keyswitch and system will not set I have tried several combinations but to no avail as the system will not set without the door contact triggering alarm (C1) or an exit fault (EF) none of the configurations make sense. HELP!!!
Paul P Posted April 14, 2006 Posted April 14, 2006 Help!!Have adopted said panel and reset the nvm chip but having the following issues as there is an external keyswitch to set / unset I have programmed the door contact as E/E and parameters 38 and 39 as lockset (opt 2) turn keyswitch and system will not set I have tried several combinations but to no avail as the system will not set without the door contact triggering alarm (C1) or an exit fault (EF) none of the configurations make sense. HELP!!! Will the system set OK if you use a code? Is the door programed as FE (Final Exit)or ER (Entry Route) there is no E/E as such? Trade Member
Guest only1reef Posted April 14, 2006 Posted April 14, 2006 Have tried 38 1 and 39 1 but wasnt sure to have door contact as F/E or E/R pretty sure I tried that though but what surprised me that even when I set Z1 as entry zone, when it was opened alarm activated
Paul P Posted April 14, 2006 Posted April 14, 2006 Have tried 38 1 and 39 1 but wasnt sure to have door contact as F/E or E/R pretty sure I tried that though but what surprised me that even when I set Z1 as entry zone, when it was opened alarm activated The entry door needs to be set to FE Final Exit as the entry route will only give a delay once the final exit door is opened. Trade Member
Guest only1reef Posted April 15, 2006 Posted April 15, 2006 Hi thanks for your suggestions Have now put Z1 dr contact as FE Para 38 opt 1 (keyswitch) para 39 opt 1 Then when i turn keyswitch cont buzzing and intermittant buzzing I like a challenge but............
breff Posted April 15, 2006 Posted April 15, 2006 Why not wire the keyswitch into a zone rather than keypad, program keyswitch to FE and door contact to ER, set opt 38 to 0 and opt 39 to 1. The system will set when the lock is closed and entry will start when it is opened. If the door is opened without activating the lock it will cause an instant alarm. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest only1reef Posted April 15, 2006 Posted April 15, 2006 Very good point but when i put system into walk test and activate switch doesnt recognise it as a zone
breff Posted April 15, 2006 Posted April 15, 2006 Very good point but when i put system into walk test and activate switch doesnt recognise it as a zone because it is currently wired into the keypad. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Paul P Posted April 16, 2006 Posted April 16, 2006 I keep having a nagging feeling that there was an issue with 9800 and key switches, something about only using them for making the system go from full to part set. Has anyone else heard this or was it one of the bad dreams and I am making myself look silly, it was 10 years + since I installed 9800 Trade Member
