Guest only1reef Posted April 16, 2006 Posted April 16, 2006 Trouble is its the same old cliche "It was working ok before" personally i dont think it was However if there are known issues then it would be good ammunition
Paul P Posted April 16, 2006 Posted April 16, 2006 Ok The Big question? Why do you want to set it with a keyswitch? It Trade Member
Guest only1reef Posted April 16, 2006 Posted April 16, 2006 Its not even an issue in programming in a code, just that i had the bit between my teeth in trying to fathom out what was happening. My theory is now that unbeknown to them the alarm was being set on the keypad and unset on the keyswitch. I'll explain.. they were led to believe that the code was to be put into keypad and then turn keyswitch on exit from premises. To me that is setting on keypad and unsetting on keyswitch Hence non alarmed premises overnight?! Then in the morning setting with keyswitch and unsetting on keypad If I'm right in my thinking then said factory has been exposed for the last 11 years
