Guest venture Posted April 17, 2006 Posted April 17, 2006 Have just installed a system using a Scantronic 9651 control unit but when I try and leave installer mode the bell tamper message continues to show (the external sounder is a Texecom Odyssey 3E). Checked all wiring and even changed external sounder to no avail. Can anyone help....??????
Guest ALSEC Posted April 17, 2006 Posted April 17, 2006 Is the tamper return from the SAB in the correct terminal on the panel? Also bend the tamper spring slightly up to make sure it is actually being held down when the lid is on!
Deltaseven Posted April 17, 2006 Posted April 17, 2006 Also make sure that when you place the cover on the bell-box, the LED's at the bottom behave correctly - should go from just one flashing to both flashing fast (if I remember correctly). This will tell you if you have a genuine bell tamper fault. The advice to bend the tamper switch leaf is good - but be careful - do it gently and just a little bit! +-edited for spelling-+
Guest ALSEC Posted April 17, 2006 Posted April 17, 2006 Also make sure that when you place the cover on the bell-box, the LED's at the bottom behave correctly - should go from just one flashing to both flashing fast (if I remember correctly). This will tell you if you have a genuine bell tamper fault. The advice to bend the tamper switch leaf is good - but be careful - do it gently and just a little bit!+-edited for spelling-+ If putting on a new SAB then when you put on the lid the right LED only flashes fast until you put 12v onto SAB then they alternate.. Can't remeber what the other meaning are but it's all in the book of words...
