C&k Securitech 800l
Guest averynp
Guest averynp
I've recently moved into a house about 6 years old with a C&K 800L system. I've got myself a User Manual off the net, but it doesn't tell me how to change the delay times on entry. Currently they are set at 30 seconds and at 63 years old that is a bit short dashing from the car into the house to unset.
Can anyone help with instructions to change the delay times
Thanks
PS I'm in New Zealand and there is a shortage of technical info down here!!!
Guest rjbsec
That's an engineering feature so you will need an engineer to make the changes.
