Accenta 6
Guest dateowner
Guest dateowner
Can anyone help?
I had a power cut 2 nights ago and since then only one zone is working (all zones operate in test mode).
I have searched high and low for the installation/engineers manual (I installed alarm 5 years ago) so I am P***ing in the wind.
I have took the battery out (measures 11.08 vdc) turned the power back on without battery connected with still the same problem! (there is nothing visably wrong with the board)
Alan
PS if it is knackered can anyone recommend a good system?
Hi ,
Can you explain a bit more..only 1 zone working? what exactly is showing on the panel , does it set / unset , do the keys respond etc.
Regards,
Guest dateowner
Hi ,
Regards,
Yep the panel activates when armed, when i press the omit button only the exit/entry zone 1, tamper and attack is illuminated (day & power is also on), the other zones dont illuminate & will not activate when pressed.
If I set the whole system only the exit/entry zone (1) works.
Alan
Guest dateowner
Mmmm . crash back to defaults and start again.
How do I do that mate????????????
Blown fuse? What are the other zones, do led's on the PIR still work?
I'm a little confused as to what you've got happening here so apologies if you've already answered the above.
QFA, prone to problems after power failure, especially if non maintained and low battery is pulling it down.
You'll need the engineer manual to default it if you don't know how, but we can't give them out in the forums. (You could be a burglar :fear: )
Post your location (town / city) & someone on the forum may be able to help you out :)
Regards
Chris
Chris Teague (Sales & Operations Manager) Sightguard Intruder Division
Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440
Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company
Guest dateowner
Regards
Chris
Yea understand, I know I have the manual somewhere, too many years out of the game. I will try to reset the system and let you know how it goes.
cheers mate.
Alan
All fuses checked they are ok, the PIR are fine I have wired them in series on zone 1, just to get me by.
I tested the all PIR with a walk test, all OK.
I will have to try to default the system. (when I find my manual)
  • 2 weeks later...
Guest dateowner
Nothing worked got to replace unit thanks anyway folks
