Optima Xm
Guest robinh
Guest robinh
Hi recently moved into a house with Optima XM alarm which had been disconnected from the mains.
Have reconnected and responds to customer code but will not reset because the attack indicator remains on.
Have tried powering down and resetting but same response should i be doing something else ?
regards
RobinH
Im not sure but is attack your PA button, see if that needs resetting.
:) do you have a panic alarm button fitted, if so you may find that it has being pressed. it will need resetting before the alarm will reset.
Guest robinh
That appears to be the problem can't seem to reset - thought powering down would solve it.
Apologies if being a thicko
RobinH
How would powering down reset it? You can only reset a panic button in one of 2 ways. Either put the key in and turn it until the window turns green or take the cover off and manually move the inards to the 'unactivated' position.
Guest robinh
Ok problem solved ...............
Attack light off can reset
result
thanks
Do not post defaulting information in the public forums
