Gartec 800
Guest wookster28
Guest wookster28
Hello,
I've just moved into a house with a Gardtec 800 installed and the code(s) has not been given to me yet. Is there a quick way of resetting the codes to default or am I best waiting until the estate agent gets back to me after the bank holiday?
I am pretty technically minded so if I can do it myself then that would be ideal
Thanks.
Guest wookster28
Unfortunately, defaulting codes is not a user option.
When the estate agent returns your call ask him when the system was last serviced, we get quite a few end users on this forums with serios problems tht would not of occured if the system was regularly serviced.
Pete
Thanks Pete, I managed to get hold of a copy in the end.
