Guest ROSEM Posted April 27, 2006 Posted April 27, 2006 Can Anybody instruct me on how to re-set my alarm. Came home from work today after estate agent had shown someone around. (am selling house) She called to advise me had problems re-setting alarm. The tamper light is flashing and will not allow re-set. Any help would be really appreciated.
morph Posted April 27, 2006 Posted April 27, 2006 Find the source of the tamper, restore the tamper, then reset the alarm as normal. Failing that call your service engineer.
Guest ROSEM Posted April 27, 2006 Posted April 27, 2006 Find the source of the tamper, restore the tamper, then reset the alarm as normal.Failing that call your service engineer. Sorry to sound like a moron, How do I find the source? Thanks
secomandy Posted April 27, 2006 Posted April 27, 2006 could be the the estate agent was typing the wrong code in the system and after 4 attemps it would go into tamper. Enter you passcode and press 0 (end) it should clear the fault.
Guest ROSEM Posted April 27, 2006 Posted April 27, 2006 Possibly keypad tamper from entrering the wrong code to many times, but has the Estate agent told you the full story?You need to speak to your installer. Pete Pete, Is there a way of re-setting from a keypad tamper? could be the the estate agent was typing the wrong code in the system and after 4 attemps it would go into tamper.Enter you passcode and press 0 (end) it should clear the fault. When I enter the code, as soon as it is entered the bells sound, and will only cease when I re-enter again. Dont you just love Estate agents.
Guest ROSEM Posted April 27, 2006 Posted April 27, 2006 Doesnt sound like it was a keypad tamper then, long shot but have you got any panic buttons pressed? No, nothing at all.
secomandy Posted April 27, 2006 Posted April 27, 2006 have you tried pressing no 3 (reset) after your code?
Guest ROSEM Posted April 27, 2006 Posted April 27, 2006 You need to find out the exact events that caused the alarm to activate from te estate agent.When was the system last serviced? Not in the last 3 yrs.
Brian c Posted April 27, 2006 Posted April 27, 2006 This may help TS510_User_Manual.pdf If you don't know......ask.
Guest ROSEM Posted April 27, 2006 Posted April 27, 2006 have you tried pressing no 3 (reset) after your code? Not yet, I think Id better leave it til tomorrow, Neighbors sleeping and all that. for your help. This may help TS510_User_Manual.pdf Brilliant Thanks
