Texecom Premier 88 And Keystone Rx600
Guest JimmyH
Guest JimmyH
I've got a Texecom 88 & a keystone rx600 to conect some wireless sensors.
I'm having some difficulty connecting the two.
I found this post:
http://www.thesecurityinstaller.co.uk/comm...881&hl=keystone
but I'm still stuck - in that post, the user ended up using relays - I'm hooking up to the zones on an RKP, so I don't have a lot of room for relays, plus I ought to be able to do it without!.
I think one of the things I'm having difficulty with is DP & EOL - do you have to change anytihng on the panel depending on which you use? I can't find any zone settings on the premier to do with this.
The keystone is hooked up to the 12v supply to the RKP.
The keystone can put out -ve or +ve outputs.
With the tamper linked out on the zone, and applying the input to the r/h terminal for the zone as directed in the prevoius post, looking at the zone status, I get:
-ve o/p, zone secure: Tamper O/C
-ve o/p, zone active: Secure 2k2
+ve o/p, zone secure: Active 8k0
+ve o/p, zone active: Tamper O/C
I realise that I'm still not totally up to speed on this!
Help!!?? any ideas?
cheers,
J
