Accenta Mini G3 Won't Reset To Factory Default
Guest Madmarty
Guest Madmarty
Hi all.
Having trouble tring to program accenta mini g3
does not respond to reprograming, just gives of a negative bleep
on all the things I want to change.
So I thought I would restore the system to factory default setting
but the procedure does not work as the system is in alarm. Does this mean Im going to have
to link everything out and listen to the bell boxs ring, just to reset ,are is there another way.
:hmm:
Sorry, but defaulting information will not be given out in the public forum.
Posting the same request twice will not help either!
If you don't know......ask.
