Optima G3 Compact
Guest timsurf60
Guest timsurf60
Hi All,
I've just fitted the G3 as a replacement for my old panel, all works OK (not impressed with the manuals!!) except the 2 beeps every 5 minutes. According to the manual this indicates a phone line fault, the manual states that this feature is not supported by the Compact and no phone line is connected. I can't find any menu to disable it, HELP.
Hi All,
Have you tried a full factory reset - as described in your manual?
Obviously you'll have to reprogram, but having done it once it won't be so bad.
