colin32 Posted May 7, 2006 Posted May 7, 2006 When using Wintex and a Premier 88, I am unable to set any user codes to a 4 digit number, it keeps asking for 5 or 6 digit numbers.Similarly, if I try to change the engineer or master code, it wont let me enter 4 digits but will accept 5 or 6 digits. Any ideas please.
Guest Posted May 7, 2006 Posted May 7, 2006 ...Any ideas please. Start to use 5 or 6 digit codes... Or search for a programming option that affects the code length.
Brian c Posted May 7, 2006 Posted May 7, 2006 The panel/software is to the new EN regs? If you don't know......ask.
colin32 Posted May 7, 2006 Author Posted May 7, 2006 Start to use 5 or 6 digit codes... Or search for a programming option that affects the code length. Surely, if the panel comes defaulted with 4 digit codes, it should allow me to change the code to 4 digits.
colin32 Posted May 7, 2006 Author Posted May 7, 2006 The panel/software is to the new EN regs? Disabling the EN50131-1 requirements has allowed me to enter 4 digit numbers - thanks.
