Scantronic 9448+
Guest millip
Guest millip
Hi
I have moved a PIR & in doing so, blew the 12v AUX fuse (F3). The alarm sounded for about 15 mins. I got a new fuse & now the tamper light is permenantly lit. When I key in the code, the control panel bleeps once. I have loop tested the tamper circuit & it is 11 ohms which I guess is about right for a working ciruit.
Any help on the next step?
Guest alarmrepairs
The panel tamper spring can be murder on this panel. Hold the spring in with your fingers and see if it clears the fault
Not sure if you are in the trade but you should ask a proffessional to look at your alarm
  • 2 months later...
Guest mayson
Hi,
Have you tried to power the system down and then back up, if this does not work I suggest you reset the panel to factory defaults and re-progam it.
John
