Independant Zone On Alarm System
Not really the proper way of doing ti though. If it's a new system then there's no reason why it can't be done properly, with a Premier 48 as mentioned above.
I'm glad the customer said no to 2 systems, no need for that at all.
Yeah, I don't think the zone omit idea is realy the way to go, though the idea is appreciated.
Have chased all the wiring from the loft where the unit will be installed down to the bedrooms and intop the floor space ready to drop into each room. Just gotta pop through in the corner of each room and in certain places where there are large windows that need shutting (mag contacts).
Just the panel and pirs to buy. Fortunately it's an emty property so no rush and no access problems. Also the house is getting re-plastered soon which makes it really easy to install.
Premier 48 is my current choice. Anyone have other suggestions for reasonably priced panels that will accept 2 or 3 keypads and offer min 2 areas?
Galaxy 2 - 20
Excellent apart from the fact it's not really a panel to fit when all you've used previously is 8 zone wholesaler specials.
Go for the Premier 48, I've fitted a couple and some on here have fitted loads. A good panel for the money, and does exactly what you want and more.
