Help To Install External Pir To Honeywell Dvr Via 15 Pin Com Port
Guest Saj
Guest Saj
I have a Honeywell DVR HRTL-One with 80gig hard drive. I want to use this so that I can record only when motion is detected.
The DVR does not have motion detection s/w built in but does come with a BNC in/out and a 15 pin COM Port pin out as described below:
pin 1 - external device control
pin 2 - external device control
pin 3 - Video loss
pin 4 - Switch out
pin 5 - error out
pin 6 - Rec start
pin 7 - external alarm NC
pin 8 - external alarm NO
pin 9 - GND
pin 10 - RS-485B
pin 11 - RS 485A
pin 12 - disk full
pin 13 - alarm reset
pin 14 - Alarm input
pin 15 - COM
I already have a camera which continuously records (via BNC in) but need to improve on this so that it only records when motion is detected in the driveway outside.
Can anybody advise on an external PIR sensor to install and which outputs from this PIR go into which pins of this 15 pin com port that looks like a serial port.
Alternatively, could I replace my camera with a camera with built in PIR and connect to the BNC input - this way, the DVR would continously record until there was video loss (ie. no movement).
Any advise would be greatly welcome.
