Spaceman Posted May 11, 2006 Posted May 11, 2006 Hello Guys, New to the forum and wondered if anyone can recommend a protocol convertor. Using the Sensormatic touch tracker with VCL domes so looking for manchester to VCL or Pelco. Any suggestions?
Nova-Security Posted May 11, 2006 Posted May 11, 2006 Manchester Bi-Phase ? www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
jelly belly Posted May 11, 2006 Posted May 11, 2006 Hi Spaceman - Welcome! There is a U.S. company that does an AD to Pelco if that helps.... http://www.sennetech.net/pdf%20files/CUTSH...CT-1000new2.pdf I'm not sure if you can get them through distribution or direct though Jelly Belly http://software4cctv.co.uk
Guest Posted May 11, 2006 Posted May 11, 2006 Hi Spaceman - Welcome!... .... I'm not sure ... Jelly Belly http://software4cctv.co.uk i am. directly.
Matt the Teckie Posted May 12, 2006 Posted May 12, 2006 I'm pretty sure that this discussion's been through on another thread? The ADTT16e (there are a number of Sensormatic Trackers) uses SensorNet RS485 data to communicate with the dome. Unfortunatly, there are major differences between conventional RS485 and Sensornet (to do with the driver chip). You won't be able to convert one to the other. Your best bet (if you really HAVE to use VCL dome) is to remove the tracker and go for something else. If you've diffent types of domes on site I'd reccomend going for something like BBV. They have protocol converts for almost every dome type you can think of (Senormatic will be driven using half RS422). Alternativly go for the Baxall ZTX7 and keyboard. Their matrix can control the Sensormatic dome up the coax (provided it's an UltraVII). Hope this helps Matt
