Dome To Sprite Cabling
secboy
Hi ! guys looking for some advice from your own experiance if poss,simple job with controls of mains complication,have to install 2060 dome to sprite2 with sprite control joy stick keyboard problem is that if I have to put the psu unit adjacent to the dome it will cause problems wiring mains to it,but if I can site the psu 25mtr away and supply the low volts via a two core cable of 1.5mm then the job is easier question; can you do this or not ?.
Paul
Ideally psu should be local, however I have had 2060's work fine over 25m with 8core 'quadrupled' up when a static has been replaced later with a ptz.
