Guest Derek Robinson Posted May 15, 2006 Posted May 15, 2006 I have an Omnicon 7000 system which is working well but I don't seem to be able to enter Engineer Programming mode. I press Programme Function, all of the LEDs are illuminated as they should be but when I enter the factory selected Engineer Code (####) nothing happens. As far as I'm aware the Engineer Code has not been changed from the factory setting. I'm reluctant to return the control unit to the Factory Set Condition although I suppose this may restore the Enginner Code.
Guest Posted May 15, 2006 Posted May 15, 2006 I have an Omnicon 7000 system which is working well but I don't seem to be able to enter Engineer Programming mode. Have you tried the skip function? Unscrew it off the wall & chunk it in the skip
kka Posted May 15, 2006 Posted May 15, 2006 Have you tried the skip function? Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
