ATI programming
Guest chris byres
Guest chris byres
Does anyone have a programming manual for an ATI6000. We need to default the panel.
Thanks B)
Your going to struggle on this one, ATI where bought out by Protection One who where subsequently bought by //.National Installer.//. You also need the programming software to be able to do anything with it.
Do a search on the forum for Ati and you will see that this question has been asked a few times.
Best solution would be to update the system or get //.National Installer.// to look at it but I dont think they will support it know and would reccomend a new system. There are a few //.National Installer.// guys on the forum and they will be able to clarify this further.
Colin.
Hi
I think you need a psion. Also it can not be reset after an activation without the reset code, i.e. can not be programmed as customer reset.
