Optima Xl6
Guest keithh1
Guest keithh1
hi hope some one can help me i do not have the user manual for my optima xl6 and i have to omit my entry zone when i go to bed because i have a pir on the landing and if we wake up during the night the alarm has to be dis armed i have looke din the gallery but that only give me one page of instructios hope someone can help
thanks
Guest keithh1
"Code" "omit zone"" (the number of the zone eg 3 if this is the landing)"" set"
thanks for your reply i may not have explaine properly but the landing is the same zone as my exit zone ie my door so when i do omit zone that makes my door not alarmed
If both areas are sharing one zone then there is nothing in the user guide that can help you.
You need to seperate them into 2 seperate zones if you have enough space in your panel, or you may want to consider an upgrade as this panel is quite old. Either way it sounds like you need an engineer to sort it out for you.
Where are you? there may be a member nearby who can help.. :)
Guest keithh1
thanks all i live in hull
Guest keithh1
KINGSTON UPON HULL
YORKSHIRE
KINGSTON UPON HULL
YORKSHIRE
Misunderstanding. Compost Corner refers to a regular professional installer who hasn't been seen in the public forums (by me anyway) for a while. I'm pretty sure he's based in Hull :)
