Help! Any One Heard Of This?
secboy
Hi guys,need help!!! My main customer has what appears to be a door access system with PC front end which is used as an intruder monitor it is labelled as CSI and was probably installed by MALGOR(remember them? I think //.National Installer.// took them over and closed down all there branches over night)the site its installed at is in essex and they have lost the 1st node comms on the data line cannot get tech support or any info am desperate to find out all I can ASAP as they are stuffed with out it working and replacement would cost mega---HELP --HELP hope some one can help me with this guys,--Regards Paul.
csi = control systems international & it was marketed in the UK by systronics who were based in basingstoke, last used their kit about 10 years ago,not bad kit if you had your DOS head on.
Yol big foot thanks for the reply,do you know if they still exist?
I know two malgor engineers I will contact them tommorrow to see if they know this system. cheers flyingboy
cheers flying boy any info will be a real help mate, Paul.
