Guest pigeon Posted May 19, 2006 Share Posted May 19, 2006 How do all Had a friend ask me if it is possible to have a cctv system fitted on his business yard,which he then can monitor from home they have no broadband only standard dial up.If this is possible can anybody advise what equipment they would need. In advance thanks for any help. Link to comment Share on other sites More sharing options...
breff Posted May 19, 2006 Share Posted May 19, 2006 it is possible, but not practical. Approx refresh rates of one frame every 8 seconds, although that may have improved with mpeg4. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
baywatch Posted May 20, 2006 Share Posted May 20, 2006 We used to do this with Geovision before broadband came in. You can only view one camera at the time, but its not to slow. Link to comment Share on other sites More sharing options...
Guest pigeon Posted May 20, 2006 Share Posted May 20, 2006 thanks for the advice Link to comment Share on other sites More sharing options...
Guest Picture Perfect CCTV Posted June 13, 2006 Share Posted June 13, 2006 How do all Had a friend ask me if it is possible to have a cctv system fitted on his business yard,which he then can monitor from home they have no broadband only standard dial up.If this is possible can anybody advise what equipment they would need. In advance thanks for any help. If a camera is connected to a pc/laptop and the pc/laptop is connected to the internet then you can log into it over the internet and view the camera scene displayed on the remote pc using one of the free log me in/pc anywhere utilities. Link to comment Share on other sites More sharing options...
Matt the Teckie Posted June 14, 2006 Share Posted June 14, 2006 If you can get your hands on a couple of PSTN routers you could use any DVR with an Ethernet port on it. Link to comment Share on other sites More sharing options...
baywatch Posted June 14, 2006 Share Posted June 14, 2006 We have a device called VisionDial (originally supplied by System Q) that allows you to monitor 4 cameras over a normal phone line (not Internet). Works pretty good, we have 1 left on the shelf, problem is you are paying for the phoneall the time,expensive if over long distance. Link to comment Share on other sites More sharing options...
