Guest KenW Posted May 29, 2006 Posted May 29, 2006 I've had last minute doubts about whether I'm wiring up correctly. I have separate quad PIRs in the lounge , dining room and kitchen. At the Texecom Veritas control panel, each PIR's alarm wires (red and black for my Texecom system) are taken to a separate pair of zone terminals (Lounge to zone3, dining room to zone 4 and kitchen to zone 5). From the three incoming cables, each white wire (12V) is taken to the Aux +ve terminal and each green wire (0V) is taken to the Aux -ve terminal. Will this arrangement be OK or must I attach all three PIRs to one zone? I intend to connect the yellow and blue wires (tamper) in series along with the yellows and blues from my two magnetic detectors as part of a global system tamper. This latter point is also causing a bit of head scratching and forms the basis for another post.
PJF Posted May 29, 2006 Posted May 29, 2006 Your doing fine, one device per zone.With the Global tamper your spot on. Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
bellman Posted May 29, 2006 Posted May 29, 2006 I've had last minute doubts about whether I'm wiring up correctly. I have separate quad PIRs in the lounge , dining room and kitchen. At the Texecom Veritas control panel, each PIR's alarm wires (red and black for my Texecom system) are taken to a separate pair of zone terminals (Lounge to zone3, dining room to zone 4 and kitchen to zone 5). From the three incoming cables, each white wire (12V) is taken to the Aux +ve terminal and each green wire (0V) is taken to the Aux -ve terminal. Will this arrangement be OK or must I attach all three PIRs to one zone? I intend to connect the yellow and blue wires (tamper) in series along with the yellows and blues from my two magnetic detectors as part of a global system tamper. This latter point is also causing a bit of head scratching and forms the basis for another post. Yes this is ok and the new detector wires the same way, DON'T under any circumstances connect more than one detector to a zone. otherwise you won't know which detector caused the alarm if it activates for any reason. as for the global tamper, just remove the last wire in the loop that goes into the control panels tamper connector and connect one of the tamper wires from the new detector in there instead, then join the wire you removed from the panel tamper connector to the remaining wire from the new detector and bobs your uncle Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest KenW Posted May 29, 2006 Posted May 29, 2006 Wow, two replies in about five minutes! Thanks PJF and Bellman. I've just posted a question about the order of connecting the tamper loops but I think I'm beginning to get the hang of it. It depends on the answer to my new "tamper" post.
