Guest kmac Posted May 30, 2006 Posted May 30, 2006 I have a bells only alarm system (Castle Care-Tech panel) and need a quote for 1) Upgrading PIRs to dual technology or similar appropriate PIR AND 2) Upgrading entire system to a monitored alarm system (would prefer alarm disarming via 5 lever lock key and not ususal key fobs) Anyone here interested in quoting I am in Greenford, Middlesex (officially Lonodn as Middlesex really doesn't exist anymore)
Guest Posted May 30, 2006 Posted May 30, 2006 2) Upgrading entire system to a monitored alarm system (would prefer alarm disarming via 5 lever lock key and not ususal key fobs) No
Anusoflannigan Posted May 30, 2006 Posted May 30, 2006 To be a little more specific, you cannot unset the system by unlocking a wired mortice lock. The lock merely starts the entry timer, you then need fobs or code to unset.
Guest kmac Posted May 30, 2006 Posted May 30, 2006 To be a little more specific, you cannot unset the system by unlocking a wired mortice lock. The lock merely starts the entry timer, you then need fobs or code to unset. I meant this version which is a combination of lock and code rather than just a fob. Thanks for putting me straight on this.
Nova-Security Posted May 31, 2006 Posted May 31, 2006 To be a little more specific, you cannot unset the system by unlocking a wired mortice lock. The lock merely starts the entry timer, you then need fobs or code to unset. DD243 states you can unset the system by unlocking the entry door as long as the lock has 20,000 differs or could be more, go with the monitored lock to disable confirmation and pin code to turn the system off thats the most secure i personally think. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
