whibbs Posted May 31, 2006 Posted May 31, 2006 if any one can help with anti mask pirs i have a set of 5 intellsense dt900 dual tech pirs with anti mask but do not what to use the anti masking is there any wayne i eather turn it of or of link it ou them out. so the anit mask does not work i have read the book but it does not help much wayne Wayne Hibbs
Brian c Posted May 31, 2006 Posted May 31, 2006 Just use the alarm/tamper relays? If you don't know......ask.
mjw Posted June 2, 2006 Posted June 2, 2006 if any one can help with anti mask pirs i have a set of 5 intellsense dt900 dual tech pirs with anti mask but do not what to use the anti masking is there any wayne i eather turn it of or of link it ou them out. so the anit mask does not work i have read the book but it does not help much wayne Anti masking will only work???...if you connect the trbl relay(trouble)
Guest RMC SECURITY Posted June 7, 2006 Posted June 7, 2006 Yeah just use the alarm/tamper relays as per normal , i.e if masked relay that is not used probably called trouble will switch , but as nothing is connected it will not affect you .
