whibbs Posted June 1, 2006 Posted June 1, 2006 can any one help i have been given two texecom odyssey 3 sounders how do i contact them both to the control panel as i do not have a wiring sheet and my panel is a premier 48 wayne Wayne Hibbs
whibbs Posted June 1, 2006 Author Posted June 1, 2006 It would depend on the control panel you have. my panel is texecom premier 48 Wayne Hibbs
ian.cant Posted June 1, 2006 Posted June 1, 2006 Oooops so you do! I dont know how i missed that but there you go. Im sure someone who knows both will be along shortly to solve that for you.
whibbs Posted June 1, 2006 Author Posted June 1, 2006 Oooops so you do! I dont know how i missed that but there you go. Im sure someone who knows both will be along shortly to solve that for you. ok thanks Wayne Hibbs
Deltaseven Posted June 1, 2006 Posted June 1, 2006 On bell one, remove the wire from MSW2, and join it to the spare core going to your second bell. (You can make a join in the panel if necessary). Connect the spare core to MSW1 (with the existing white wire) in bell 2. Use the tamper return from bell one to link to the panel. Good luck! D7
Anusoflannigan Posted June 1, 2006 Posted June 1, 2006 Also make sure one of them is set to SCB and the other SAB. There is a jumper on the Oddysseys next to the battery terminals. I believe this panel cannot cope with two sirens in SAB mode.
