Guest italiastar Posted June 1, 2006 Posted June 1, 2006 Having fitted my system, I'd like to upgrade the sensors and fit more. I have a Aluminium patio door and a wooden framed window and door. Do you recommend vibration sensors for these to stop someone getting in and if so what type - I can easily get Vybe, Optex or Viper. Are these prone to false alarms and is there an optimum part of the frame to fit these - Any hints on fitting these would also be most welcome - many thanks.
Guest Posted June 1, 2006 Posted June 1, 2006 Please refrain from starting several topics with same subject.
