Guest David F Posted June 3, 2006 Posted June 3, 2006 Hello From a retired ex Spark who has no alarm experance, Tate alarm bell box type.T-B650, Control Box T-BP8Z No Install Manual I am replacing a damaged bell box to my system which was installed in 1998 and the wireup in the replacement bell box is differant. Old Box ST R SW V+ V- White Green Blue Red Black (Wire Colours) New Box STB HoldOff + Holdoff - RTN TRG Control Box ST S + R Aux wht Blue Yell Grn Re/Black Please Can anyone Help David
Service Engineer Posted June 3, 2006 Posted June 3, 2006 old ======= new ST ===== STB R ===== RTN SW ===== TRG V+ ===== HOLD OFF+ V- ===== HOLD OFF- That should do the trick. ........................................................ Dave Partridge (Romec Service Engineer)
Guest David F Posted June 3, 2006 Posted June 3, 2006 old ======= newST ===== STB R ===== RTN SW ===== TRG V+ ===== HOLD OFF+ V- ===== HOLD OFF- That should do the trick. Many Thanks for that David
Service Engineer Posted June 3, 2006 Posted June 3, 2006 Where's the Yellow from the Control panel.? ........................................................ Dave Partridge (Romec Service Engineer)
Guest David F Posted June 3, 2006 Posted June 3, 2006 Where's the Yellow from the Control panel.? The yellow was unconnected in the old bell box when opened by me to replace it and connected to the + term in the control box as below. ST========white S ======== blue +======== yellow R========green
