Eurosec Key Pad
Guest lee8810
Guest lee8810
how do i disable the service due warning on a eurosec keypad :angry2:
Get your System Installer back to service the system.
If you installed it yourself, there is a section in the installation manual that covers this.
Guest lee8810
i was going to service myself but i need to know how to turn service due warning off
The details needed are in the engineering manual, if you did not install the system yourself then presumably you wont have the manual.
Then your only option would be to get the installer back to service it as engineering manuals are not available to the public.
