james1990 Posted June 4, 2006 Author Posted June 4, 2006 Hi all, one more question. Do you think that the rkp is included in this item: http://www.gx-security.co.uk/scantronic-96...rade-p-926.html Thanks to everyone, James
Guest ALSEC Posted June 4, 2006 Posted June 4, 2006 The 9651, 9752 & 9851 all come with 1 x 9930 RKP as standard (well the pre-EN versions did anyway).
Guest Sh4rpie Posted September 27, 2006 Posted September 27, 2006 most standard PIR detectors will be able to have the 'creep zone' blanked off with that tape method you described. IR will not pass through the tape to be detected. i have a large cat and this causes no problems with the 'Response' system that i have installed in my house or the wired systems i have installed elsewhere.
