LeonThePro Posted June 4, 2006 Posted June 4, 2006 Do most dome cameras have the ability to adjust the camera position within the dome? I am particular interested in this one Would a 3.6mm lense be ok for covering an aisle in a corner shop? (internal ceiling mounted about 12ft from the floor) Also can anyone recommended a another dome for around the same price as the one listed above?
ian.cant Posted June 4, 2006 Posted June 4, 2006 Yeah you should be able to have adjustment of view with that dome. I would advise you to check with the supplier that the dome can be wall mountable aswell as ceiling mountable, some are ceiling mount only and dont have a 3 way type gimball effort. Unless of course your not bothered. I couldnt suggest a suitable alternative as the domes i use are supplied to trade only, try System Q though.
baywatch Posted June 4, 2006 Posted June 4, 2006 If you want to ceiling mount most domes can adjust in 2 plains. For good reliable supplier try http://rfconcepts.co.uk
Guest netvisiondvr Posted June 7, 2006 Posted June 7, 2006 you could look at Panisonic's,we used it,woked well.
Paul Main Posted June 8, 2006 Posted June 8, 2006 The focal length of the lens needs to be cosen to give the angle of view required. Generally, a shop isle will require a narrower lens than the 3.6mm one mentioned which will generally give a widish angle view. Most dome suppliers offer a range of lens focal lengths - or for a bit of extra cash -vari-focal lenses which can be set on site. Paul Main ClearView Communications Ltd Robjohns Road Chelmsford Essex CM1 3AG Telephone: 01245 214104 Fax: 01245 214101 paul.main@clearview-communications.com www.clearview-communications.com
