Accenta 8
Guest Kath Brown
Guest Kath Brown
We've got an accenta 8 that had a PIR in the conservatory, which we have knocked down, leaving the PIR dangling outside. At this point everything was working ok, providing we omitted that one when using the alarm. We then removed the PIR to pull the wire through the wall to the inside of the house and reconnected it. various alarms and lights flashed until we entered the alarm code then everything looked normal. Except when we tried to use the alarm, it wouldn't work and we noticed all the PIR's aren't lit up at all, we've reset it, but still no joy. Anybody any ideas what's wrong or even better how to fix it?
I think you will find that the 12volt auxiliary fuse has blown on the main control box circuit board.
Colin.
Guest Kath Brown
Colin
Thanks, we've just replaced the fuse we think you're talking about, marked "F1 1.6A to protect +ve line of 12 volt battery", but the PIR's still aren't picking up movement. Have you any other ideas?
there should be an another fuse marked aux supply or similar which will be the fuse controlling the output(power) to your pirs.
paul
THE BLACK KNIGHT
Guest Kath Brown
I've just replaced the fuse and it's all working.
Thanks very much.
i wish all my service calls could be done so simply - i would,nt have to drive anywhere!!! ^_^:lol:
paul
THE BLACK KNIGHT
