Speaker Audio And Infra Beams
whibbs
i set up a premier 48 panel with 10 zones and 2 infra red baems, i have an audio outputer with speakers. the beams are the only two entry ponts and both are set as entry/exits zones with a time of 45 seconds can i set the audio ouput to sound if only when the entry time runs out before the user code is input i have set the output on my panel as entry/exit but the speakers go off when we leave the area i have tried to set the output as entry only but speakers go off before we can get to panel. can you help please its driving me mad??
wayne
Wayne Hibbs
Your output on you panel will set it off if it is entry/exit, as it it programmed the output activates on entry/exit.
Try programming the output as bell or intruder output, could you not wire these sounders up to trip from the bell output?
What type of speakers are they ? and what do you mean by a audio outputer?
www.nova-security.co.uk
www.nsiapproved.co.uk
Guest ALSEC
wayne
What is an outputer??
Am I right in thinking that in the event of not entering a vaild user code within the entry timer then you want the speakers to sound?
audio outputer sends out a voice message to warn the interuder to leave area
that why i what to use the just two beams set off the speaker and not the rest of the zones also not to set off the bell with the beams
do you see what i mean
yes that right but not to sound the sounder but only to be set off by the beams not the rest of the zones
Wayne Hibbs
ive seen them linked to 240v pirs..is this the sort of thing you have...
no its all 12 volt and a standed alarm with standed pirs
Wayne Hibbs
