Guest Dead Ringer Posted June 5, 2006 Posted June 5, 2006 For the first time in 15 years I have foolishly undertaken the installation of a wireless panel - The Infinite! All of the sensors/mag switches/ keyfobs etc. are from the same manufacturer but the siren is a Zintec Armour flash through a wireless sounder module. Everything seems to work apart from being unable to get the thing to set. I have programmed out all of the sensors bar the entry/exit mag switch (which works on the walk test) and have tested the sounder successfully. TX strengths are all good (9). Attempting to set from the panel just gives five short bleeps and setting from a key-fob four. After half a day guessing and awaiting divine inspiration, I am bordering on failure....Any ideas?
Guest Dead Ringer Posted June 6, 2006 Posted June 6, 2006 Ring TLC and tell them there kit doesn't work. Thank you for your useful and insightful advice. I rang TLC who wondered how I knew about their kit, seeing that I hadn't bought anything from them. ESP were a little more understanding and fixed the problem.
