Guest 1976saint Posted June 6, 2006 Posted June 6, 2006 Hi, I have Gardtec 350+ alarm system and it intermittently goes off without being set. When I reset on the panel it gives me a 66 code? Anyone know what this means?? Regards Paul.
Wooly-bobs Posted June 7, 2006 Posted June 7, 2006 Are you sure its not a 360 or a 370? Twin 7 segment display? Its probably bb not 66, in which case there is more than likely a bell box tamper problem. Time for a shiny new bell box i think.
Guest 1976saint Posted June 7, 2006 Posted June 7, 2006 Could be, no marking on the kit. Onlygoing by pictures on the web. The manual say GARDTEC 300/500 series, GARDTEC 360/580 User instructions, guess its a 360. Sorry if I'm being thick but the bell box is unit on the wall outside or the one inside? Is this a common problem with house alarms as I remember at my old house the first thing the maintenance company did was replace the outside box. Thanks for you reply... Paul. Are you sure its not a 360 or a 370?Twin 7 segment display? Its probably bb not 66, in which case there is more than likely a bell box tamper problem. Time for a shiny new bell box i think.
Guest Alarm Guard Posted June 7, 2006 Posted June 7, 2006 Yep, the bell box is the box outside (which almost certainly doesn't have a bell, but a siren) And yep, it is a common problem. The units suffer from weather, extremes of temparature, Etc. much more than any other part of the alarm ... And Roger types faster than I do.
